1995 Dodge Neon Stabilization
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
JMC102
I need to stabilize my car for a long abscence (10 months.) What would i need to do for that.
May 18, 2010 at 7:49 PM
SERVICE WRITER
  • 9,123 POSTS
I would do is try to get the car in a temperature controlled environment if possible.
I would run the fuel down to a 1/4 tank. When you revive the car, put fresh gas in and change the oil. the battery will drain down, so either it will need occasional trickle charging or plan on charging battery before restarting.
May 19, 2010 at 12:17 AM
