1995 Dodge Neon running hot
1995 DODGE NEON
110,000 MILES • 4 CYL • FWD • AUTOMATIC
KENLMCKINNEY
i have a 1995 neon and it is running hot. i am not running the ac and it is not leaking antifreeze anywhere that i see. any help would be greatly appreciated. thks
Jul 27, 2008 at 11:39 AM
LEIGHANN DURAN
  • 6 POSTS
If it's not leaking check the water pump or thermostat!
Aug 5, 2008 at 8:09 PM
J55GUY
  • 8 POSTS
The first thing you want to check is for a head gasket break. If theres no leaking of oil or anti-freeze on the ground, open the radiator cap when its cool and see if theres oil mixed in. then check the oil dipstick for anti-freeze. If either of those things are happening, you have a blown head gasket. Neons are well known for blowing head gaskets. I have a 97 neon with 84000 miles and I am now replaceing the head gasket for the third time. This time I'm not useing a Chrysler gasket, they suck. I hope this helps.
Aug 7, 2008 at 7:46 AM
