1995 Dodge Neon reverse light
KALO
Electrical problem
1995 Dodge Neon 4 cyl Two Wheel Drive Manual 130k miles
reverse light always on; car runs great otherwise; on neutral gear cable centered on trx; I mention all this because auto is a trx convert to manual from automatic.
Many thanks for your help.
donation guaranteed upon answer/advice leading to actual solution of problem
Feb 8, 2009 at 12:05 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_186.jpg
start with the back up switch unplug it does the light go out if so replace the switch
Feb 8, 2009 at 12:27 AM
KALO
Reverse light stays on after unplugging back up switch; any suggestion leading to actual repair guarantees gratuity; many thanks
Feb 9, 2009 at 12:23 AM
BMRFIXIT
  • 19,053 POSTS
Then u have a short in the wiring system and need to check it
check what else feeding it
was any wiring done have it rechecked
Feb 9, 2009 at 8:47 AM
