1995 Dodge Neon parking lights
JOSHWITMAN
Electrical problem
1995 Dodge Neon 4 cyl Front Wheel Drive Automatic
i have a 1995 dodge neon and recently the fuse to the parking lights blew. I changed the fuse and right as i turned the lights on it blew again. i've taken the head light switch out and checked wires going to and from that and the fuse block none of the wires seem to be loose. I've also checked all bulbs and wires going to all lights. i have found nothing and fuses keep blowing can you tell me where and what i should be looking for i'm not mechanically stupid i'm pretty good with cars but when it comes to electrical i'm at a loss. thank you for any advice.
Josh witman
Oct 12, 2008 at 7:03 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect the problem is in one of the sockets check if you had the radio changed check its wiring check any electric work done on the car if any check the wiring harness need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_7.jpg
Oct 12, 2008 at 1:15 PM
