1995 Dodge Neon Overheating Problems
GO_GETTA88
  • 1995 DODGE NEON
  • 4 CYL
  • FWD
  • 170,000 MILES
My 1995 Dodge Neon has recently been having overheating problems. I sealed the leaks in the radiator, replaced the thermostat (I think the old one was still operable), replaced the housing, added oil, repaired the radiator fan, and the coolant reservoir is full, but within minutes my car has overheated everytime I've went for a test drive. As far as I know the water pump isn't leaking either. I'm also hoping not to have to spend much more money as I am on a budget. What should I do next?
Thursday, April 2nd, 2009 AT 3:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to have head gasket inspected for cracks. Neons are very common to have head gasket failure.
Thanks for using 2CarPros. Com!
Thursday, April 2nd, 2009 AT 3:30 AM
GO_GETTA88
  • 7 POSTS
Alright I will definitely try that
Thursday, April 2nd, 2009 AT 11:05 AM
GO_GETTA88
  • 7 POSTS
Ok so everything was good with the head gasket. Now I noticed that there's a leak near the top of the radiator where it bolts to the chassis. Any suggestions as to how to slow down or stop that leak?
Friday, April 3rd, 2009 AT 6:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
There are producst such as JB Weld that do a wonderful job of patching up small leaks such as this. You may want to try that out. Of course the best permanent fix would be a new radiator.
Friday, April 3rd, 2009 AT 6:55 PM
GO_GETTA88
  • 7 POSTS
Sounds like a good idea. I want to replace my radiator within a month so I just need it to work until then. So is there a specific type of JB Weld I should use since there are several different types?
Friday, April 3rd, 2009 AT 7:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Just use the original JB WELD epoxy. If you use the JB KWIK it may not withstand the temperatures under the hood.
Friday, April 3rd, 2009 AT 7:23 PM
GO_GETTA88
  • 7 POSTS
Thanks. Well that didn't work too well so I just bought a new radiator. I'm hoping that will take care of the issue. Is there anything else I can do that will also reduce engine heat?
Friday, April 24th, 2009 AT 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Well since you just have a radiator installed your cooling system should have been flushed out very well so just keep the appropriate level of coolant in the system and keep an eye on the temp. Gauge. If you suspect overheating you may want to inspect components before the overheating damages anything.
Friday, April 24th, 2009 AT 2:57 PM
GO_GETTA88
  • 7 POSTS
Thanks, it works pretty well now and I will definitely keep track of the coolant level
Saturday, April 25th, 2009 AT 3:11 AM
