1995 Dodge Neon Overheating problems
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
BWYRICK
My 1995 dodge neon has had overheating problems from the start, i have quite literally run through at least 3 thermostats and i recently replaced the head gasket. Currently, Currently, there is hardly a thermostat in there, i cut out the inside of it so that more antifreeze could run through, but after running it during the day yesterday it started to overheat again. I have no A/C so i know that is not the reason that it was overheating, what could it be?
Let me know, thanks!
Blair
Feb 10, 2009 at 5:35 AM
  • 75,988 POSTS
Check the radiator if its clogged and water pump operation if okay -get it block and pressure tested
Feb 10, 2009 at 5:56 AM
BWYRICK
that all is fine
the fans dont blow, is that it?
Feb 11, 2009 at 5:40 AM
  • 75,988 POSTS
Wire the cooling fan direct to the battery if it works-test the fan relay and the coolant temperature sensor
Feb 11, 2009 at 1:44 PM
