1995 Dodge Neon overheating
JOSED1285
Engine Cooling problem
1995 Dodge Neon 4 cyl Front Wheel Drive Automatic
hi, i'm trying to get a second car only to drive to work and back i found a car but the person tells me that the cars a little bit under 125,00 1995 dodge neon automatic he says that one time while driving to his house for 1 1/2hrs at 65mph it overheated he waited aliitle bit til it cooled down and added some coolant then the ride was ok for the rest of the trip (sorry he also mentioned that the a/c didnt work) now as an hvac mechanic i might have an idea that there might be a leak some where but what i would like to know is it worth me buying the for $675 and getting the repairs done or no and what do you think it might be? please any advice would be very helpful and appreciated thank you.
May 20, 2008 at 10:20 AM
  • 75,988 POSTS
Overheating could be caused by a blown headgasket cracked head and block- etc.
To find the problem
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
May 20, 2008 at 11:03 PM
