1995 Dodge Neon No spark no Fuel
4 CYL • 2WD • MANUAL
HUNT2KILL
I rebuilt the engine in my 95 dodge neon, After the rebuilt we started the engine without a problem it ran really well for 30 minutes at an idle. All of a sudden the rpms droped and the car shut off (just like if someone had turned off the key) I'm not getting a check engine light or oil pressure light..... the only code I could get was a "recent battery disconnect" ( I no longer even get this) the timing belt is still turning and is in the correct position. I checked the fuel injectors and they arent spitting gas and the spark plugs wont spark. The key still turns over the engine. And I have replaced the Computer 3 times! I've gone as far as to test every wire in the car for a ground and power and double checked with a ohms meter. I have checked the relays ans fuses inside and outside the car nothing burnt and everything is functioning I have located the ASD relay and nothing is wrong with it.the only thing I found was there was no power from computer to the idle air control value/motor when i disconnected the sensor and tryed to start the car i still didnt get a check engine light Im comfused? I've tryed everything any ideas?
Oct 28, 2009 at 1:44 PM
BMRFIXIT
  • 19,053 POSTS
was the ignition switch checked
do you have power at fuses
and ignition fuses
Oct 28, 2009 at 2:33 PM
HUNT2KILL
yah checked the ignition switch and power to fuses, everything is working thats the problem!!
Oct 28, 2009 at 3:07 PM
