Electrical problem
1995 Dodge Neon 4 cyl Front Wheel Drive Manual
hi,
my 95 neon is a SOHC 2.0 and i have replaced the cam sensor and crank sensor checked the wiring, the coil pack tested good and so did the plug wires, the connector for the coil pack is not hot when the key is turned on i even had the alternator checkout for some odd reason..lol and the pcm says code 12 and 55 which mean there nothing wrong whats going on? can u help me
hi,
Mar 7, 2009 at 10:27 AM
