1995 Dodge Neon no fuel Pulse & no spark
DARRELLM
  • 1995 DODGE NEON
Electrical problem
1995 Dodge Neon 4 cyl Front Wheel Drive Manual
hi,
my 95 neon is a SOHC 2.0 and I have replaced the cam sensor and crank sensor checked the wiring, the coil pack tested good and so did the plug wires, the connector for the coil pack is not hot when the key is turned on I even had the alternator checkout for some odd reason. Lol and the pcm says code 12 and 55 which mean there nothing wrong whats going on? Can u help me
Saturday, March 7th, 2009 AT 6:27 PM
BMRFIXIT
  • 19,053 POSTS
Check timing belt
check ASD relay
Saturday, March 7th, 2009 AT 8:22 PM
WAMPY81
I had a similar problem to what your talking about and sadly enough after a lot of work, it was fuse #21, a 20amp large blade fuse under the hood that controlled the fuel pump and the coil both. I'd check that fuse to see if it's blown. Damn fuses!
Wednesday, March 11th, 2009 AT 8:46 AM
