1995 Dodge Neon master cylinder
1995 DODGE NEON
BIGGUY23
Brakes problem
1995 Dodge Neon 4 cyl Front Wheel Drive Manual
How do you replace a master cylinder on a 95 Dodge Neon .
May 23, 2010 at 3:00 PM
  • 31,937 POSTS
Undo the fluid level indicator plug, undo the hydraulic lines, undo the master cylinder mounting bolts, bleed the new cylinder on the bench, re fit cylinder and attach hydraulic lines, re bleed full drake system re attach fluid warning wire.
mark (mhpautos)
May 23, 2010 at 8:44 PM
