1995 Dodge Neon growling front end
1995 DODGE NEON
14,400 MILES • 4 CYL • FWD • AUTOMATIC
XERXIES
  • 10 POSTS
hi
have a growling in my front end changed the two front wheel bearings( not the problem)..had mechanic check the cv joints,(fine ok) checked rear bearings also ok, what gives here, dont know what eltse to check,new tires,recent front end alinment,
only problem i have to correct is the inner tie rod worn and loose but that cant be whats growling could it!!! thanks guys, patrick.
ps more pronounsed on right turns not as much on left turns.by the way tie rod thats going is right side also.
Jun 7, 2008 at 4:15 PM
BMRFIXIT
  • 19,053 POSTS
Tie rod end may give you a clapping or so noises
also I would check the rear bearing too
Jun 8, 2008 at 11:47 AM
