1995 Dodge Neon fuse
95DODGENEON
Electrical problem
1995 Dodge Neon 4 cyl Front Wheel Drive Automatic
i keep blowing fuel pump relay on my neon. it is the first gen. i checked the fuel pump, fuel pump relay. all good if you dont try to start car(key in off position) fuse is good. once you try to start it, fuse blows everytime i also checked my injectors they are good. any ideas on what to try or which direction to point me?
All the fuel pump , relay and injectors, and sending unit all tested good
Oct 2, 2008 at 4:21 AM
MERLIN2021
  • 17,250 POSTS
Trace the dark green/white stripe wire at the pump, it must be shoring out to ground. Or the pump is fried.
Oct 2, 2008 at 10:06 AM
