1995 Dodge Neon Fuel pump fuse?
100,646 MILES • 4 CYL • FWD • AUTOMATIC
K_ROC11A
Hello, I have been having trouble with my dodge neon. The car seems to start most of the time without the fuel pump fuse popping, but when I go to drive it the fuse blows. I have had the fuel pump out and tested. I have replaced the computer. I could use some good news. Thank you.
Kevin
Mar 23, 2008 at 10:16 AM
BMRFIXIT
  • 19,053 POSTS
does it crank when the fuse out
you may want to check wiring and the starter too
we had a similar issue with a Stratus
turn out to be a bad starter
Mar 23, 2008 at 10:38 AM
