1995 Dodge Neon Fuel pump
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEOM
I've changed the fuel pump and relay couple months ago.
My car stopped last time because the fuel pump was not running. After waiting couple minutes I could hear again running pump when I turn the key on.
Usually after waiting it's running again.I can't figure out what causing that because it's working again.
Feb 29, 2008 at 5:38 AM
  • 75,988 POSTS
Hook up a fuel pressure gauge and monitor the pressure this will tell you the performance of the pump
Also inspect and test the ASD relay
Feb 29, 2008 at 2:48 PM
