The car has a grinding noise in the right front. I removed the half shaft, and the inner joint seems fine, but the outer joint doesn't move quite as freely, but it doesn't seem to bind either. Also, the wheel hub doesn't seem to spin quite as freely as it should, but I don't have anything to compare it too, as the car sits now.
The car also sometimes does not want to turn right at low speeds, but there is no resistance turning left.
Wheel bearings, half shaft, or something else?
Thank you for all your help.
Oct 25, 2008 at 9:53 AM
