Hello, check trouble codes. You should be able to get codes by cycling the ignition switch. On--off, on--off, on, you just turn the key till the dash lites come on, no further. The mil starts flashing, you count the flashes to get the codes.
When the problem occurs, check for spark at the plugs and injector pulse. It would be nice if you could get it to stall in the drive-way. Right now, the problem could be almost anything?
SPONSORED LINKS
Wednesday, February 18th, 2009 AT 12:21 PM
