1995 Dodge Neon acceleration
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
RVRWND
when I step on the accelerator the car won't go, I have to pump the accelerator and eventually it will get up some speed, it shifts fine once the speed gets up, but can't get it to pick up speed. Could it be the fuel filter or possible need a new catalytic converter?
May 12, 2008 at 1:15 PM
BMRFIXIT
  • 19,053 POSTS
you need to check 1st
check fuel pressure
try removing the O2 sensor before the cat and if you notice improvement then suspect the cat
is it do for tune-up
May 12, 2008 at 1:53 PM
