I am hoping someone here will be able to help me out as i have searched and searched the net. I currently have a 1995 Dodge Neon 2.0 DOHC 5 Speed manual. I am putting in a 1999 2.0 DOHC engine. I know when my mother swapped hers out, ( 95-96 ) all the sensors had to be taken off the old motor, and put on the newer motor, the 1996. Even that in itself i dont think was right, as when the connect one vacuum hose, the car dies ( idles real low and eventually stalls ) and her check engine light stays on. Anyways, a solution for that would be great too. Back to my problem, I am going from a 95 motor, as i said, to a 99 motor. I have been told to just swap the sensors out, and some even said i should have to get the 99 model pcm. Please, someone let me know what I need, everything i need to do to get this project on the right path and finished up. thanks.
EDIT: On a side note, i know its not much, but you guys have helped me out before, so i have donated 10.00. As i said its not much but every little bit helps. Thanks again guys
Jan 4, 2008 at 12:50 PM
