1995 Dodge Neon Coolant Overflow Surge
Suggested Repair
Perform a compression test on each cylinder and inspect for a cracked cylinder head or a failed head gasket related to the recent valve and gasket work. Do not assume the throttle body is causing coolant to be forced into the overflow. If the problem began immediately after the dealer repair, hold them accountable.
Conversation Summary
A 1995 Dodge Neon with 160,000 miles began surging at idle and forcing coolant into the overflow until the radiator emptied after the dealer replaced the exhaust valves and head gasket. The dealer replaced throttle-position sensor wiring and later recommended a throttle-body replacement under an old service bulletin, but neither addressed the coolant loss. The owner says neither symptom existed before that work and can tolerate the surge but not driving without coolant. The expert advised a compression test on each cylinder and raised a possible cracked cylinder head, while questioning whether the engine had overheated before the repair.
