1977 Dodge Neon
150,000 MILES • 4 CYL • 2WD • MANUAL
TONYAHAWK
I got in my car and tried to start it and got nothing. The battery is full of charge and the lights and gauges work. It just didnt want to start with the key. However being a stick shift..i was able to push start it. What could be the first possible problem that comes to mind????
Jul 31, 2010 at 1:29 AM
  • 75,988 POSTS
No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay, clutch switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Jul 31, 2010 at 1:41 AM
