Serpentine belt and temp gauge
MYERSBUCK
  • 22 POSTS
Hello and thanks for the help (I know nothing about repairing anything). I have two questions about my 1997 dodge ram 1500 v8 magnum 140,000miles, 5.9 360. 4x4 (Centruion special edition)
Question 1) I reciently bought the truck and when I start it about 90% of the time there is a squeeking noise comming from the engine (it squeeks repetidly). I took it in (repair shop) and he replaced my cerpintine belt and I left and now a month or so later its back to the squeeking. My friend said spray it with like a WD40 and true the squeek does go away but only for a day or so. Any suggestions to a perminante fix?
Question 2) My dodge also has on the inside on the top console and gauge that digitaly says the direction and temp of outside. The North South East West works like a charm but the temp will do a few things...A) not say anything B) give me the wrong temp (random temp not even close). I tried to reset it and do the 2 360 turns in under 60 sec but that doesnt work and I think that is to reset the directional unit anyways though. Anyone know how to help?
Thank you again and sorry for my bad spelling also.
Mar 5, 2007 at 1:59 PM
MIKE H R
  • 3,094 POSTS
with the serpentine belt off, check all the pulleys, clean them good with a wire brush, {sometimes worn rubber get in the groves} , check the pulleys to see if they all turn farely free. when you put the belt back on make sure it is seated correctly. check the tensionsioner and make sure the belt is tight enough.
Mar 6, 2007 at 1:00 AM
MIKE H R
  • 3,094 POSTS
with the serpentine belt off, check all the pulleys, clean them good with a wire brush, {sometimes worn rubber get in the groves} , check the pulleys to see if they all turn farely free. when you put the belt back on make sure it is seated correctly. check the tensionsioner and make sure the belt is tight enough. the guage could be from a bad ground check the wires.
Mar 6, 2007 at 1:01 AM
MYERSBUCK
  • 22 POSTS
Ok...once I can get my truck in a garage (live in Michigan and its cold cold cold) I will try that. Thank you so much
Mar 6, 2007 at 4:38 AM
MIKE H R
  • 3,094 POSTS
I live in ny and the temp is now 13 with a wind chill of -17. also check the pulleys to see if they are not worn or loose or out of adjustment
Mar 6, 2007 at 5:57 AM
