Check Engine - 1997 Dodge Ram
DELLIOTT101
Hi, new user with some questions...
I have a 1997 Dodge Ram 1500 V6 Magnum. 137,395 miles. Since the great state of California requires the autos to be smogged (ugh) I'm in a dilemma. The Check Engine light has been on for awhile.
The truck has been running fine. Here's what I'm wondering:
The previous owner put in a K&N air filter. I got a cleaning/oiling kit and cleaned it shortly after the light went on. I have seen on the 'net that these filters can cause problems. Is that anyone's experience? Should I go to the junk yard and replace this thing with a Dodge air filter assembly?
Wondering if too I should change the plugs. When I got the truck it has 112,335 miles on it. I just don't know if there is a trick to getting to the plugs in the back of the engine (it looks cramped back there).
Oh, one last thing... a few months before I started getting the CEL, the battery came loose and broke open.. acid all over. I cleaned the engine and took it to a garage, as the belts needed replacing. It ran without the light coming on for months, so I don't know if that's related. The mechanic checked it all at the time and no problems...
HELP!
Jan 16, 2007 at 8:32 AM
CARUNDELL
  • 602 POSTS
[quote:125d169e5f="delliott101"]Hi, new user with some questions...
HELP![/quote:125d169e5f]
Hey d,
First and foremost I would need the code# and its description. You can get a free scan at most major auto parts chains. Get back to me w/ the info and I can help ya more!
Chris
Jan 16, 2007 at 10:57 PM
DELLIOTT101
Hi Chris,
I sent you an e-mail.. here's the info on it:
The diagnostic code I got was P0138 which is "O2 Sensor High Voltage (Bank 1 Sensor 2)". Also, my "HC (PPM)" Measure is 102... the mechaninc said it should be 100.
I know a little bit about cars and truch and can probably do this myself... if you have any suggestions, I would appreciate it!
Thanks,
David
Jan 19, 2007 at 8:42 AM
