2007 Dodge Magnum electronic throttle control
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRG3400
after driving awhile ( the time doesn't seem to matter) the electronic throttle control light will come on followed by the electronic stability program light. I have taken to a dodge dealer and they replaced map sensor, but this has not helped.
Jul 6, 2010 at 9:38 AM
KHLOW2008
  • 41,812 POSTS
Hi crg3400,
Thank you for the donation.
What was the trouble code retrieved?
Did you refer back to the dealer which performed the job?
Jul 8, 2010 at 7:39 AM
CRG3400
the codes are p2173, p2638, c121c. taking the car back to the dealer tomorrow
Jul 8, 2010 at 12:23 PM
KHLOW2008
  • 41,812 POSTS
Our database site is under maintenance so I am not able to get the required information. Will get back to you once the site is ready.
Jul 9, 2010 at 4:05 AM
KHLOW2008
  • 41,812 POSTS
I have sent the diagnostic files to you. Let me know if you require anything further.
Jul 9, 2010 at 9:18 AM
RONZO
I have the same problem, 2006 with 90K. What was the fix?
Apr 19, 2012 at 2:11 PM
RIVERMIKERAT
  • 6,106 POSTS
P2173:High airflow: Vacuum leak detected. (Slow accumulation)
P2638:Torque management feedback signal performance.
C121C:Torque request signal denied.
Run a diagnostic on the PCM and ABS controller.
May 6, 2012 at 5:18 PM
KARLA1107
Hello I have a 2007 dodge magnum that has the same problem... can u help me with my codes to see what's wrong with my car. Thank you.
Sep 23, 2014 at 2:03 AM
RIVERMIKERAT
  • 6,106 POSTS
Hi Karla,
We'd be happy to. Please start a new question thread and list the codes that you have received.
Sep 28, 2014 at 1:10 AM
