2007 Dodge Magnum codes
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRUMP88
  • 11 POSTS
My check engine light came on in my Dodge Magnum. The code I am getting on my scanner is P1004 ECU Battery feed and power grounds, can you tell me what this is I looked in the manual and this code is no where to be found?
Oct 11, 2009 at 5:02 AM
SERVICE WRITER
  • 9,123 POSTS
Check your purchase date, this should be within the 3yr/36,000 mile warranty.
Oct 11, 2009 at 11:08 AM
TRUMP88
  • 11 POSTS
[quote:869153d5ef="trump88"]Electrical problem
2007 Dodge Magnum 6 cyl Two Wheel Drive Automatic 35000 miles
My check engine light came on in my Dodge Magnum. The code I am getting on my scanner is P1004 ECU Battery feed and power grounds, can you tell me what this is I looked in the manual and this code is no where to be found?[/quote:869153d5ef]
I have a Dodge magnum service manual I cannot find this particular code, and the Dodge warranty has expired. I just need to know what this code is and how to fix it.
Oct 11, 2009 at 2:20 PM
TRUMP88
  • 11 POSTS
I need to know what and how to fix this code P1004 ECU battery feed and power grounds for my 2007 Magnum can anyone help me.
Oct 11, 2009 at 2:24 PM
SERVICE WRITER
  • 9,123 POSTS
Is this the 3.5 motor? If so, The p1004 code is most likely due to a broken short runner valve in the intake manifold.
https://images.2carpros.com/forum/automotive_pictures/30961_mag_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_mag2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_magsr2_4.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_mag33_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_mag33a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_mag33b_1.jpg
Oct 12, 2009 at 12:01 AM
