2007 Dodge Magnum car window wont role up
MICKEY702
2007 Dodge Magnum
I rolled down my window on the drivers side and it wouldnt roll back up. All of the other windows are working fine the little light on the door where the buttons are have a green dash like there is still power. I tried turning the car off and slamming the door still not working, any suggestion on what I might be able to do at home to fix the problem.
Mar 11, 2010 at 8:39 AM
DUMMY1980
  • 5 POSTS
It isn't the motor in the window . They have metal tracks they slid in and more often then not the plastic clips that hold the glass in the track break its a easy fix pop of the door panel and find the track it looks like a sisior or a "x" use a flat head screwdriver to remove the old clips slide the old clip out the bottom of the track. slide the new one in the same way. when the new one lines up with the proper ball use a pair of chanle locks to gentley snap it back into place
Mar 24, 2010 at 11:22 AM
