tail light fuse location?
2005 DODGE MAGNUM
JTREBER
Electrical problem 6 cyl All Wheel Drive Automatic 60000 miles
the tail lights will not work all the fuses are good and the bulbs are good, all other lights work in front and rear. The front parking lights are working, The license plate light isn't working. I checked for power on the tail light and plate socket and no power. I removed the panel and found a small group of wires coming from the rear going to the fuse box, should there be a plug?
Help me please - this site rocks!
Jan 18, 2009 at 8:14 AM
  • 55,390 POSTS
There is a tail light relay that sound like it has gone out, Here are a few guides and the tail light wiring diagrams (below) for you to do some testing and get the problem fixed.
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Jun 12, 2017 at 9:02 AM
JANVIER36
My rear lights nor the front park lights are not working. I have changed the fuses and they keep burning out. What else should I do?
Apr 16, 2019 at 11:24 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Suspect faulty bulb try removing see if fuse stops blowing. inspect each bulb see if a filiment has broken and touching base
JANVIER36
I replaced both bulbs in the back. i even replaced the license plate bulb.
DOCFIXIT
  • 18,828 POSTS
What about front?
Heres the wiring diagram for the exterior lights for your car
HALLESTRAWBERRY3
tail light fuse location i need to change it
Dec 14, 2020 at 12:59 AM (Merged)
  • 55,390 POSTS
Here is a guide to help you test the fuse with the fuse location in the diagrams below.
