Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Magnum
Drivetrain
Transmission
Gear Selector
Stuck
2005 Dodge Magnum stuck in park
2005 DODGE MAGNUM
70,436 MILES • 6 CYL • 2WD • AUTOMATIC
SHAWN1219
MEMBER
1 POST
the car is stuck in park and i wondering what the problem may be.
Apr 24, 2008 at 1:13 PM
BMRFIXIT
Experienced Mechanic
Thinks to look for and check
1. check fuses
2. check if you have brake light when u step on the brakes
3. check brake light switch
4. check shifter lock solenoid
5. check wiring
Apr 24, 2008 at 1:58 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
