how do i change the rear brake light bulb?
60,000 MILES • 4 CYL • 4WD • AUTOMATIC
EBONY_WILLIAMS1
May 24, 2008 at 4:12 AM
SQM
  • 6,383 POSTS
The brake light bulb can be changed fairly easily on this vehicle.
First open the rear hatch. There is an access panel that is located behind the light assembly, remove the panel. This will give you access to a nut that keeps the light mounted. Remove that nut. Then you will have to remove two plastic fasteners on the side of the light housing. This will allow you to pull out the taillight assembly.
Then simply remove the burnt bulb and install it by simply working in reverse.
https://www.2carpros.com/articles/brake-lights-not-working
Jan 29, 2022 at 10:48 AM
