2005 Dodge Magnum Magnum cutting out.
76,000 MILES • V8 • 2WD • AUTOMATIC
BHULL0014
I have a 2005 Dodge Magnum and it has recently started cutting out every so often like it is starved for fuel. Its mainly at a low speed because I can usually get it to stop by pushing the gas more and driving it a little ways. I also noticed when it happens and I have the air on the air is not cold. It does trip the check engine light but it does not stay on. I have hooked a code reader up to it but all it gave was a multiple misfire. Like I said the weirdest thing is that it might only happen once or twice a month for a few miles. I know it could be several things just wondering if anyone has any insight. Thank you
Sep 23, 2010 at 12:11 PM
EKILSTROMROADRUNNERCOM
same problem on an 06...trouble codes as follows in order read...po315 crankshaft position system variation not learned, po300 random/multiple cylinder misfires detected, po335 crankshaft position sensor A curcuit malfunction...then more recently a p1411 and a p1417 ( the p1 are powertrain manufacture specific) related to secordary air injector- incorrect flow..help big time!
Apr 7, 2013 at 12:11 PM
DRCRANKNWRENCH
  • 3,380 POSTS
Check your fuel injectors with a test light. If one is bad replace it. If multiple injectors are bad you might need to replace the injector driver. The other thing you should do is get the fuel pressure checked.
Apr 14, 2013 at 1:21 PM
