fuel pump
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
OFFSHORERIDER
how do you install the fuel pump?
May 16, 2008 at 12:41 PM
THE MAGIC
You do not need to drop the furl tank to change the pump out because it is under the rear seat but you will need to drain the gas here is a video showing you how.
https://youtu.be/Q5MH2gnyFH0
Here are diagrams (below) to show you how to remove the fuel pump.
Cheers
Feb 26, 2009 at 12:37 AM
