2005 Dodge Magnum engine surging
2005 DODGE MAGNUM
80,000 MILES • V8 • 2WD • AUTOMATIC
BTOUZEL
i have a surging issue at different rpm ranges, there is no check engine light, i have scanned it no codes,
Jun 10, 2010 at 4:33 PM
Lack of acceleration,surging,chugging,hesitating,bogging etc. could be caused by one of the following below.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 10, 2010 at 5:47 PM
