2005 Dodge Magnum Electric
56,500 MILES • 6 CYL • FWD • AUTOMATIC
GMOYA1972
My Battery light comes on and my panel lights and headlight flicker when Im driving. What is causing it?
Dec 16, 2008 at 11:58 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me the model of your vehicle. Is it a RT, SE, SXT. Also the engine size in liter and the 8th digit of your VIN.
Dec 17, 2008 at 9:08 AM
GMOYA1972
my model car is 2005 dodge magnum RT. Engine is a 2.7 liter, V6 engine. and the 8th digit of the vin is a (T).
Dec 18, 2008 at 12:09 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info……….just a note though……..are you sure the 8th digit starting from the left is a “T”? When I look at the 2.7L engines the only VIN is an “R”
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Also check your belt tensioner.
My thought……either your alternator is not putting out correctly or you belt tensioner is not keeping enough pressure on your belt.
Let me know what you find out from AZ.
Dec 18, 2008 at 2:30 PM
GMOYA1972
O.K. got you my information, my 2005 DODGE MAGNUM SE (VIN: 2D4FV48T45H622379) 2.7 liter, V6. My lights flicker and my battery light comes on. Any Idea.
Dec 30, 2008 at 12:52 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info……..did you do as I suggested yet and go to AZ or OR - if so what was the result
Dec 30, 2008 at 3:10 AM
