vehicle just past 80k warranty on the catalytic converter. vehicle has 8080 miles and check engine light came on , auto zone check says pblm w/ c. converter trouble shooting code P0430.took to dealer, diagnosis invoice says : found bank 2 catalytic converter failure. ran emission efficiency test and catalytic converter failed. re.catalytic converter and 021 sensors .
they also noticed transmission fluid dip stick missing, so replaced it w/a oil filler cap. a previous mechanic noticed also hose was disconnected and some screws not properly tightened which he connected and reset chk eng light to go off and said if light retn in a few days or week it was not that gas cap improperly on-night before i fill up tank of gas. could the hose that was disconnected or loose crews along w/dip stick for transmission missing (all of which was located under hood on right side up front-can't remember name of part the unhooked hose goes to)have caused any of this? some one said the mileage too low for catalytic converter pblms. what do you think?
Oct 13, 2009 at 2:57 PM
