2005 Dodge Magnum all lights flicker
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
SARMODCOLLIER
all lights flicker at randome times ocasionaly the battery light comes on. the car has never standed me . starts every time. took it to a shope they replaced alt the problum persists.
Feb 5, 2009 at 2:51 PM
  • 110,248 POSTS
Actually it sounds like a ground problem. Check for loose or damaged body ground straps. Also, make sure the ground to the engine block from the battery is tight and clean.
Mar 10, 2009 at 4:35 AM
