2002 Dodge Magnum Cylinder 2 missfiring
2002 DODGE MAGNUM
158,000 MILES • V8 • 2WD • AUTOMATIC
LANCEBOHANAN
My truck enigine light came on and i went to autozone to get it check. It said cylinder 2 miss firing. I replace the spark plugs the fuel injector, distruter cap, and rotor. The enigine light will come on and go off when i driving it. But the spark plugs keeps getting fouled out, there is no oil on the spark plug, there is alot of carborn on it. I check the compersion on cylinder 2 it was good. When i start it up and i hold the gas pedal between 1500 to 2000 rpm it starts to cut out. i might think it is the coil or distripter losing power. What do you think. can you help me out?
May 24, 2010 at 6:55 PM
Fuel pressure could be low, bad fuel, an EGR valve that's open, weak coil and sparkplug wire.
May 24, 2010 at 7:04 PM
