1996 Dodge Magnum lights go out
1996 DODGE MAGNUM
XPGRINDER
Electrical problem
1996 Dodge Magnum V8 Four Wheel Drive Automatic
the headlights go out after about 5 minutes o use.... the fuse box seems to be hot....there is no voltage regulator, tried to buy one..auto zone said the computer contros the voltage...altenator seems to be good
Oct 17, 2009 at 1:34 PM
You got a bad contact on one of these the headlight switch or the dimmer switch w/o a DRL -if it has a DRL check the DRL module
Oct 17, 2009 at 8:11 PM
