Sputters and hesitates
2009 DODGE JOURNEY
45,000 MILES • 4 CYL • FWD • AUTOMATIC
RUDY HILBERT
When I am driving at approximately sixty to seventy mph, and I accelerate, especially going uphill (up gradient) the vehicle sputters and hesitates.
Nov 9, 2010 at 6:36 AM
  • 110,244 POSTS
This can happen when the ignition system is misfiring or if the fuel pump is failing. Here are two guides that will help you fix the issue:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and
https://www.2carpros.com/articles/engine-hesitates
Cheers
Nov 19, 2010 at 6:40 PM
ROBERTGREYSTONE916
Thank you so much. I installed a set of spark plugs and the car has never ran better! I love this site.
Jul 2, 2018 at 8:21 AM
RICH6464
I have the vehicle listed above 3.5L v6. What is it and can I fix it? I have already been to the dealership and they want to replace the computer and they want over $900.00 to fix it. I have read online that others have already done this and it did not fix the problem.
Jul 2, 2018 at 8:22 AM (Merged)
Hold them responsible for the repair. If it does not fix it, tell them you want a refund. Get it in writing. The bid sounds right.
2009? You have a five year, 50,000 mile warranty. Did you see if there was any coverage left for you?
JDUBBS-1
It has been stumbling while in gear and idling (at stop lights, in parking lots). This generally happens after a length of driving at consistent speed and then coming to a stop fifteen to twenty minutes of driving over forty mph and then stopping at a light is usually when it occurs, but it is random and not every time. The check engine light came on for a few days and went off. I had the code checked and it said multiple misfires detected. I took in to the dealer and they did a software update for the cylinders. A few days later the problem has resurfaced. If I shift into neural when it starts to stumble, it stops stumbling and regains a smooth idle. Also accompanying this issue while driving at low speeds and accelerating, on multiple occasions, the rpm's increase, but the speed does not increase appropriately and then suddenly, as if something breaks free, it accelerates rapidly and then drives normal at a steady speed. I am taking it back to the dealer next week, but I would like to give them some leads to follow so I am not going through trail and error.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge auto parts rent it. Check for a vacuum leak if a misfire cheapest option if for a mechanic to fix due to can be a sensor, injector as well as other basic engine problem.
https://youtu.be/YV3TRZwer8k
