Popping noise in steering when cold
_RUGRATS_5
I have a 1995 Dodge Intrepid with 68,000 miles on it. The problem only occurs when the weather is cold: there is a very loud "popping" sound when turning the steering. It usually goes away after driving a couple of blocks. The noise sounds like metal getting in a bind and then snapping back. It occurs with even small turns of the steering wheel, not just when cornering. Thanks for your help
Dec 3, 2006 at 10:52 AM
PAINTER420
I have a 96 interpid that does the same thing....anyone got any ideas?
Nov 19, 2007 at 1:33 PM
CHICAGOMACK
[quote:865a1dfad8="_rugrats_5"]I have a 1995 Dodge Intrepid with 68,000 miles on it. The problem only occurs when the weather is cold: there is a very loud "popping" sound when turning the steering. It usually goes away after driving a couple of blocks. The noise sounds like metal getting in a bind and then snapping back. It occurs with even small turns of the steering wheel, not just when cornering. Thanks for your help[/quote:865a1dfad8]
I have a 97 intrepid that was doing the same thing. What I found was that the bushing for the bottom frame needed to be replaced. Also, If your steering is hard to turn, you may also have a bad power steering pump. Have a look into these ideas.
Feb 28, 2008 at 10:18 PM
