no spark in 2,3,5,6,
DANNYBEUCK
  • 5 POSTS
I have a 99 dodge intrepid 140k miles on car 0 miles on motor.I just installed a 2002 rebuilt 2.7L engine. I cant seem to get spark I am geting spark out of no.2 and 3 but no others i have checked the crank and cam sensors and they seem fine I also checked the coil packes they are fine and have no shorts and good grounds.I also have power and ground to the pcm and no trouble codes are coming up what could this be?bad PCM ??? or do I need to have the car programed by the dealer? any help would be great I am a auto body tech in need of a machanic
Oct 26, 2007 at 7:20 PM
SERVICE WRITER
  • 9,123 POSTS
IT is really strange that no codes are showing when it has to have misfires on some cylinders.
What led up to the engine replacement, anything that could have already had those symptoms or was it the typical oil sludge problem they had?
Oct 27, 2007 at 12:20 AM
DANNYBEUCK
  • 5 POSTS
yes, the car had a rod knock and threw it threw the block
Oct 27, 2007 at 3:26 AM
DANNYBEUCK
  • 5 POSTS
well after two GM techs come by and looked at my car they said it was the PCM so I bought one only to have the same problem!!!!!!!!!!!!!!!!! and less money someone please help!!!!!!!!!!!!!!
Nov 9, 2007 at 9:48 AM
SERVICE WRITER
  • 9,123 POSTS
IF you have anti-theft, the pcm needs to have it programed into it' This is out of mitchell. Do you still get spark on the same cyls or none of them now?
Nov 10, 2007 at 9:15 PM
DANNYBEUCK
  • 5 POSTS
[quote:c0282b15b7="Service Writer"]IF you have anti-theft, the pcm needs to have it programed into it' This is out of mitchell. Do you still get spark on the same cyls or none of them now?[/quote:c0282b15b7]
i still only have spark on the same cyls
Nov 25, 2007 at 12:05 PM
DANNYBEUCK
  • 5 POSTS
[quote:c600111fb1="dannybeuck"][quote:c600111fb1="Service Writer"]IF you have anti-theft, the pcm needs to have it programed into it' This is out of mitchell. Do you still get spark on the same cyls or none of them now?[/quote:c600111fb1]
i still only have spark on the same cyls[/quote:c600111fb1]
I also dont see a light that says theft on dash or alarm ect
Nov 25, 2007 at 12:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:5c315a4cc6="dannybeuck"][quote:5c315a4cc6="dannybeuck"][quote:5c315a4cc6="Service Writer"]IF you have anti-theft, the pcm needs to have it programed into it' This is out of mitchell. Do you still get spark on the same cyls or none of them now?[/quote:5c315a4cc6]
i still only have spark on the same cyls[/quote:5c315a4cc6]
I also dont see a light that says theft on dash or alarm ect[/quote:5c315a4cc6]
hello
If I recall right the 2.7 have 6 coils on it
U has to pull wire of each one and check if you have power and when cranking u get pulse
With key on all should have battery power on one of the wires?
And the PCM will ground and pulse the other wire if that is happening the coils are bad if not happening
Trace the wiring and then if all ok and good u can say the PCM bad
Very uncommon but can happen
Check if u plugged the wrong wire in a wrong pluG
It’s not a cam or crank u have spark on 2 cylinders
WIRES………. COIL …………PCM
Good luck
Let me know
Nov 25, 2007 at 1:22 PM
