2004 Dodge Intrepid Stalls, Cam Sensor
GREG_NETTLES
Hello out there. I have a 2004 Dodge Intrepid SE. I have problems with my cam sensor. I have replaced it twice and still get a check engine light, and the car stalls on the highway. HELP!
May 26, 2007 at 11:55 AM
E40WATER12
  • 522 POSTS
With the check engine light on again, Is it listing youre cam sensor still broken? I would take a close look athe wiring harness on the cam sensor, Also inspect the wiring and connections for breaks.
May 27, 2007 at 1:25 PM
OLDTECH2
  • 64 POSTS
Double check your codes. I'd also check the crank sensor on the bell housing.
What do the old sensors look like when you remove them? Is there damage or debris on the end of it?
May 27, 2007 at 2:09 PM
Suggested Repair
Recheck the trouble codes to confirm they still point to the camshaft position sensor. Inspect the cam sensor wiring harness and connectors for breaks or poor connections, examine the removed sensors for damage or debris, and also check the crankshaft position sensor on the bell housing.
Conversation Summary
The owner of a 2004 Dodge Intrepid SE replaced the camshaft position sensor twice but still has a check engine light and highway stalling. Experts advised confirming the stored codes, inspecting the cam sensor wiring and connections, checking the crankshaft position sensor, and looking for damage or debris on the old sensors.
