Dodge Intrepid
KURSETH
  • DODGE INTREPID
I have a 1995 Dodge Intrepid. The problem is intermitten but very troublesome when it happens. When I turn on the car or occassionally while I am driving, the guages (tach, speedometer, indicator light, heat guage) will stop working and the car will not shift out of low gear. I had it in a garage twice and each time they did something (tighten a ground wire and something with the computer). The problem is still happening. Sometimes it snaps out of it within a few blocks, sometimes it takes considerably longer (7 or 8 miles). Any help as to what this is or what I can do will be greatly appreciated! Thank you!
Thursday, January 11th, 2007 AT 9:34 AM
KOBY
  • 28 POSTS
Sounds like the Output Speed Sensor is going out. I had a Dodge Stratus that did the same thing. If you leave it like that it will never shift out of low after a while. There is a panel in the drivers side front wheel well (stratus) take it off and the Output Speed Sensor is there on the tranny. Cost about $20 at Advanced or Auto Zone.
Friday, January 19th, 2007 AT 7:31 PM
KURSETH
Thank you very much for responding! I will give this a try and if you are correct I owe you a huge thank you, as no one has been able to figure this out yet. Thanks again!
Friday, January 19th, 2007 AT 8:57 PM
KOBY
  • 28 POSTS
Thank you very much for responding! I will give this a try and if you are correct I owe you a huge thank you, as no one has been able to figure this out yet. Thanks again![/Quote:b8d716b1d0]
just give me a reputation on the website
Saturday, January 20th, 2007 AT 8:46 AM
