Can any body help?
[quote="spyrosgolias"][quote:5eb5d5d68e="vandragon"]when you turn the key to on without starting the engine, does the fan come on? if so it sounds like a stuck fan relay! if it goes off when the key is turned off it won't hurt anything, just keeps the car running cooler at idle. if you just bought the car then the fan maybe hot-wired and relay bypassed![/quote
First, thank you for getting back to me.
When the key is turned on without running the engine, the fan is not running. I tried the two fan relays allready. I removed them and the fans went out. And also I exchanged the relays with others of the same kind from the relay box, but I still had the same results. I bought the car new eleven years ago, so, the wires are not by passed.
The problem is: when I first start the car and when the engine ice cold in the middle of the winter the cooling fans start running at high speed. It's not fun when I try to warm up the engine. I changed the coolant sensor but nothing changed.
Thanks again,
Spyros[/quote:5eb5d5d68e]
May 8, 2006 at 9:38 AM
