cooling fan
DODGE INTREPID
SPYROSGOLIAS
  • 9 POSTS
Dodge Intrepid 1995, 123,000 miles
The cooling fan is running all the time while the
engine is working.
Any suggestion?
I"ll appreciate your help very much!
May 4, 2006 at 6:37 PM
VANDRAGON
  • 298 POSTS
when you turn the key to on without starting the engine, does the fan come on? if so it sounds like a stuck fan relay! if it goes off when the key is turned off it won't hurt anything, just keeps the car running cooler at idle. if you just bought the car then the fan maybe hot-wired and relay bypassed!
May 5, 2006 at 3:39 PM
SPYROSGOLIAS
  • 9 POSTS
[quote="vandragon"]when you turn the key to on without starting the engine, does the fan come on? if so it sounds like a stuck fan relay! if it goes off when the key is turned off it won't hurt anything, just keeps the car running cooler at idle. if you just bought the car then the fan maybe hot-wired and relay bypassed![/quote
First, thank you for getting back to me.
When the key is turned on without running the engine, the fan is not running. I tried the two fan relays allready. I removed them and the fans went out. And also I exchanged the relays with others of the same kind from the relay box, but I still had the same results. I bought the car new eleven years ago, so, the wires are not by passed.
The problem is: when I first start the car and when the engine ice cold in the middle of the winter the cooling fans start running at high speed. It's not fun when I try to warm up the engine. I changed the coolant sensor but nothing changed.
Thanks again,
Spyros
May 5, 2006 at 6:34 PM
SPYROSGOLIAS
  • 9 POSTS
Can any body help?
[quote="spyrosgolias"][quote:5eb5d5d68e="vandragon"]when you turn the key to on without starting the engine, does the fan come on? if so it sounds like a stuck fan relay! if it goes off when the key is turned off it won't hurt anything, just keeps the car running cooler at idle. if you just bought the car then the fan maybe hot-wired and relay bypassed![/quote
Thanks again,
Spyros[/quote:5eb5d5d68e]
May 8, 2006 at 4:38 PM
VANDRAGON
  • 298 POSTS
this has me spumped. if i can get away with this..call the parts store AZ if you know which i mean and ask.
May 11, 2006 at 10:15 AM
SPYROSGOLIAS
  • 9 POSTS
[quote:825dea210b="vandragon"]this has me spumped. if i can get away with this..call the parts store AZ if you know which i mean and ask.[/quote:825dea210b]
Dear Vandragon,
I am not sure if I understand where to go from here for more help. Would you be able to assist me further with this problem?
Thanks a million!
May 11, 2006 at 6:54 PM
SPYROSGOLIAS
  • 9 POSTS
[quote:350d74f91f="spyrosgolias"][quote:350d74f91f="vandragon"]this has me spumped. if i can get away with this..call the parts store AZ if you know which i mean and ask.[/quote:350d74f91f]
Dear Vandragon,
Thanks a million![/quote:350d74f91f]
Dear Losone,
After reading one of your emails on this site I 've decided to email you to ask for help. It seems that you specilize enough to give me an answer on my big problem.
Car: 1995, Dodge Intrepid, 123,000 miles
The cooling fan on this car is running all the time. As soon as I start the car it goes on. I changed the coolant sensor, but did not take care of the problem.
I also checked the fan relays: they seem to be okey.
Can you help?
Thanks a lot!
May 14, 2006 at 7:11 PM
LJC
Check your relays to make sure one has not melted itself into the "on' position.
May 17, 2006 at 1:00 AM
SPYROSGOLIAS
  • 9 POSTS
[quote:8c522bdf3e="ljc"]Check your relays to make sure one has not melted itself into the "on' position.[/quote:8c522bdf3e]
1995 Dodge Intrepid, 123.000 miles
I removed the relays and tried five other similar relays
from the relay box. I always got the same results. When I would plug-in a relay, the fans would start running. Now, I mainly run the car without having the relays plugged, that means the fans are out.
But I can not get stuck in traffic. If so, it will over heat.
More assistance needed...
May 17, 2006 at 6:34 PM
HORACEMAC
I had this same thing happen at almost the same mileage, but my fan ran all the time, even with the key off!!
Took it to a dealer shop, since I was not home & did not have time to look into it myself.
Dealer changed the primary coolant sensor. This item will run the fan after the key is off IF the engine is too hot to leave it after stopping.
You may need to have a good shop look into this.
Good luck,
Horace
May 19, 2006 at 11:42 PM
REEGS37
  • 19 POSTS
Did you figure it out? I have a 96 Intrepid with 121,000 miles and its doing the same thing, I need help too.
Jun 23, 2006 at 8:58 AM
SPYROSGOLIAS
  • 9 POSTS
Hello, how are you?
Nothing yet. All I did for now is removed the high speed relay. See there are two fan relays in the relay box. Now the fans are working all the time, but, in the low speed. That's better. Other than that I am still looking to find the answer on this problem.
Spyros
Jun 25, 2006 at 10:20 AM
REEGS37
  • 19 POSTS
I know what you mean, I did the same thing with the relays and they just keep running, I tried disconnecting the battery for like 2 hours hoping to reset the computer, I thought maybe that would do something, but didn't work, I have a friend of mine who's a mechanic, I told him about it and he said he would call a fried of his who works for Dodge but that didn't happen yet. I'll keep you posted if I find out anything.
Jun 26, 2006 at 6:49 AM
REEGS37
  • 19 POSTS
Finally found the problem, it was the high pressure switch SKY, my friend was looking at my air conditioning, the compressor was turning on for about 5 minutes and then shutting off, which of course wasn't blowing cold air, so he put it on his scanner and it came up with the code for the pressure switch, which is located at the bottom left of the radiator ( cost him $ 81.00 it listed for $101.00 and he had to order it thru Chrysler ) but if fixed both of my problems, I now have cold air and the fans ares working properly now. WEW, I was beginning to think there was no cure. He had to cut and splice the 3 wire leading to the switch because of the conection on the new part did not mate the old plug.Let me know how you make out if you change yours. By the way is your air conditioner working right?
Jul 12, 2006 at 6:43 AM
