1994 Intrepid; 130K miles
Airbag and ABS lights come on and the power windows and climate control stop working. Problem is intermittant and is the latest in a long series of electircal gremlins possibly related to BCM. I replaced ignition switch, checked fuses. I heard of a TBS 080595 NHTSA # 39986 that might explain the problem but cannot find a copy online. Any dangers in replacing BCM with used unit? Possible bad ground somewhere?
Oct 4, 2007 at 8:34 AM
