2004 Dodge Intrepid PO441 codes
LILDAY50
  • 2004 DODGE INTREPID
  • 6 CYL
  • 117,000 MILES
I have a po441 code on my car. I have to get it inspected. I would like to know the normal cost for repair.
Saturday, December 20th, 2008 AT 3:26 PM
  • 109,885 POSTS
Hi:
That is an EVAP code which means there could be many reasons why you are leaking fumes from the fuel system. Most common is a bad fuel cap or a rusted down pipe (the steel pipe that goes to the fuel tank from where you put gas in the car).
What I suggest to save a lot of frustration is have the system fogged. A mechanic will fill the EVAP system with fog. Then he will look to see where it's leaking out of the system from. It's the easiest way to find it.
Let me know if you have any other questions.
Wednesday, December 24th, 2008 AT 9:50 PM
