2004 Dodge Intrepid oil pan light comes on
LILDAY50
  • 2004 DODGE INTREPID
  • 6 CYL
  • 117,000 MILES
I want to know what the problem could be when the oil light comes on when I stop and goes off when I continue to drive. Also I smell oil when I get out of the car. The oil levels are ok.
Wednesday, January 28th, 2009 AT 10:51 PM
Do you hear any type of knocking noises? If not get a mechanical gauge and check the oil pressure if normal replace the oil pressure sending unit abnormal reading could be an oil pump and engine bearings etc. As for the oil smell could be a leak somewhere-investigate and then get back asap
Thursday, January 29th, 2009 AT 2:53 AM
