2004 Dodge Intrepid Loss of power RPM goes up
MRSLESLIEDON
Engine Performance problem
2004 Dodge Intrepid Front Wheel Drive Automatic 131000 miles
A few weeks ago while at a red light my car jumped and when the light turned green and I pushed the gas the RPM went up but the car barely moved. I pulled over turned the car off then turned it back on and it was fine. This problem is occuring more often now about every time I drive it but if you turn it off and back on again it's fine. On the highway it's fine but when you get off and start again the speed goes down and the RPM goes up again.
Aug 10, 2009 at 5:03 AM
BMRFIXIT
  • 19,053 POSTS
Check tranny fluid
check TCM for codes
suspect tranny issue
Aug 10, 2009 at 10:39 PM
