2004 Dodge Intrepid engine wont fire
144,000 MILES • 6 CYL • FWD • AUTOMATIC
LAURELRIGGS
driving my car yesterday quit while i was driving went to start it and it turns over but will not fire
Apr 2, 2010 at 7:22 AM
  • 75,988 POSTS
Do below to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 2, 2010 at 10:06 AM
