2004 Dodge Intrepid Dodge intrepid has trouble starting and
DODGESWEETIE
Other Category problem
2004 Dodge Intrepid 6 cyl Wheel Drive Type unknown Automatic 135000 miles
It has been cold lately and my car has problems starting. It floods very easily and once I do get it started, I have to give it gas constantly or it the RPM's drop to 0 quickly and stalls. It starts back up right away.
Feb 9, 2008 at 5:22 PM
  • 75,988 POSTS
Check the engine coolant temperature sensor and the idle air control valve and throttle position sensor.
Feb 9, 2008 at 5:47 PM
DODGESWEETIE
Thanks for the quick reply....do you think it could be the fuel injector or fuel pump?
Feb 10, 2008 at 12:48 AM
  • 75,988 POSTS
Check the above 1st-then the fuel pressure and injectors-could be just fuel freezing up
Feb 10, 2008 at 12:52 AM
